Hope this is the right spot to put this.
2007 LBZ ExCab, Short Box Classic. How does everyone else's MBRP kit fit?
Mine was a joke, all the parts matched to instruction sheets, but fitment wasn't even close. Hangers were way off where they needed to be, and I had to Torch/Bend 2 out of the 3 just so they could come close to going in the isolators on the frame. When we got to the back, the axle dump exited more than half into the spare tire, so I had to remove the spare tire (which isn't a big deal, but the instructions claim to clear the tire fine)
Worst part is after everything was installed, the Chrome Tip doesn't even fit? Tip Fits on the 18" spare extension pipe the kit came with, but the axle dump tail pipe is slightly larger in Diameter than the inside of the Tip. I would say its about 1/16" larger than it should be, and there is no way in hell I can get the Tip on the pipe. Only way I see it getting on, is taking it to a Shop and getting the Tip expanded a bit...
I've worked on a lot of cars over the years, no diesels until now, so I REALLY don't think it is me screwing this up, but I won't toss that out completely yet . Buddy and I were under there for probably an hour spining and moving the pieces around before tightening the hangers to see if it would go differently to no avail...
