I just bought a 2001 lb7 last week and a massive fuel leak started the other day. The leak comes from the back of the engine, and drips from the back of the oil pan onto the ground. I replaced the fuel pressure regulator and the two rubber return lines above the cp3, drained the oil and no diesel fuel came out with the oil. I checked the fuel filter, fuel return lines to the tank and I still can't determine where the leak is coming from. What could be causing this issue??? I'm stumped. Any help would be great.
