I need to retune the maf in my truck and would like to know what the normal flow rate should be from idle up to 2000rpm as I am seing 10 psi of boost at 1800 rpm cruising on highway. I made new intake and maf is much closer to stock turbo now and I assume that since no other changes made, the maf is seeing higher airflow being closer to turbo inlet therefore cooling the maf and requesting more fuel hence more boost. My fuel mileage is a joke right now so need to retune it.
Also what is stock idle rpm?
Sent from my SGH-I257M using Tapatalk
