I just did a suncoast kit in my 5speed. In the process I made a novice mistake that I'm curious if I'm screwed or not. Long story short I pulled the springs off of the C1 spring cage, slightly bending the ends in the process. I realized it was the wrong cage after thery were all off and I went to put the new springs from the transgo kit on. Anyways I got all the springs as straight as possible, but even still this made the snap ring that holds the C1 spring cage insanely tight... am I screwed? or will be okay? If not what should I do? Thanks in advance.
