Lowering an LB7
bubbaburger911
Jul 14, 2014
30
New Jersey
I am looking into lowering my currently stock height LB7 2-3" using drop shackles in the back and lowering the torsion bars in the front. Does anyone know if it will have any effect on the pinion angle or will i be fine leaving that alone?
Noreaster
2,910
42
Cape Cod,MA
I removed the overloads & running a 2" drop, pinion angle wasnt great so I added 4 degree shims which gave it a better angle
jollybuildingmover
Apr 21, 2015
They make degreed shims if you decide you need to adjust your pinion at some point,.
04 3500 LB7 C&C
We move Portable Buildings!
bubbaburger911
Jul 14, 2014
30
New Jersey
thanks for the help. I am going to try just going with the drop shackles alone first, and if i want it lower I'll give removing the overload springs and installing shims a shot
