Looking for weld on spring perches that fit an aam 11.5
Sledheadxp800r
That was only my tow tune
Dec 13, 2010
1,151
CT
Im having some troubles finding a pair of perches big enough for the rear axle in my puller. Anyone know where I can get a pair?
Thanks
Jesse
HotRodTractor
Ford Driver
Nov 29, 2009
56
I bought mine from Ballistic Fab. They have them for both the 3.5" and the 4" axle tubes as well as the 2.5" and the 3" wide springs.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
33
Lexington, Ky
I wanted to do this also, better check your rules. Bob rules says factory suspension mounts must be retained.
Sent from my PC36100 using Tapatalk 2
juddski88
Freedom Diesel
Jul 1, 2008
4,651
116
Chesterfield, Mass.
I wouldnt do it jessie. that's gonna put a lot more stress on the tube and it's going to bend and snap your axles. it's been pretty well proven out in the mecca that the SRW axle housings are not up to the task. I would try ot find a C&C rear end that is already narrower and stronger, and build the rear of your frame off of that. Then you'll have a nice track width too, you wont be churning as much loose dirt
z79outlaw
Apr 20, 2007
793
Salem WI
I bought the balistic fab perches last year before they had them on website through there custom order options they were really nice pieces and I think like $ 30-35 to my door.
Sledheadxp800r
Dec 13, 2010
1,151
CT
I'm gonna run the stock rear for now. When it bends or breaks ill change it. I don't think ill be in that much loose dirt with the wheels I have. The fronts are 3 1/2" backspacing and the rears are 10 1/2" backspacing.
While the axle out ill throw a half ass truss job on it
juddski88
Freedom Diesel
Jul 1, 2008
4,651
116
Chesterfield, Mass.
Ballistic stole 180 bucks from me...never shipped the parts I ordered and always dead ended my calls after that incident...I wouldn't recommend buying a peanut from those mf-ers.
Sledheadxp800r
Dec 13, 2010
1,151
CT
Our rules state stock suspension style.... IE no 4-linked rears. You are allowed to change spring geometryand placement
Copied directly from the MATPA 3.0 class rules
Rear suspension: A solid suspension is permitted, but must still use OEM mounting points.
I know for a fact the other guys aren't using OEM mounting points.
