LML Knock and 150 psi
ikeG
Oughta Know Better
Apr 19, 2011
2,429
128
Western PA
www.facebook.com
Got a lml in that makes a knocking noise. Balance rate on cyl 7 was 10. Had codes for that and cyl 6 injection timing. Compression test showed 150 psi on 7 and good on all the others. Could see piston top damage with borescope. Tore it down today to find this.
Sent from my SM-G990U2 using Tapatalk
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,040
246
At Da Beach
Probably just the pistons cracking. Look at the spray pattern, the chunks missing are right where the fuel is hitting the piston.
1,611
That piston was coming apart for sure. Look at that crack across the bowl from the broken out chunk. Ike, are there divots in the cylinder walls besides that one on the very top?
ikeG
Oughta Know Better
Apr 19, 2011
2,429
128
Western PA
www.facebook.com
Cylinder walls are fine except for the pics I took. Head is beat up but should be fine. I agree that a chunk of the piston broke out, and did the rest of the damage we see until it made its way out exhaust valve.
