LML cp3 conversion troubles
diesel vein
Apr 2, 2011
15
3
So I know I'm still considered a new guy but I do have some street cred on duramax forums if yall hate on me. I have done a couple of these conversions with little to no trouble and some not even having to be retuned to run well. I have been putting in stock lbz pumps.
This is a 2016 cab and chassis that had the classic cp4 failure. I installed lbz pump and new lml injectors and started and ran like a top, but anything above +- 10percent throttle it will stutter and stumble and shake and almost die out. Sometimes it will. I thought, well maybe it needs retuned. Nope... same thing. I isolated the pulp return line to rule out a kink, isolated the fuel tank and sucked fuel out of a bucket into the fuel filter, no codes, desired and actual rail pressure are very close through it all. I replaced the fpr on the pump to be sure, and removed the regulator on the rail and cleaned. Wasnt very dirty....
I sweated on this beast all day and am out of gas on it. Wow. Does anybody have some suggestions. At idle it will rev to 3k for a second then cut out sputter and rattle and almost die. Then with it floored will hold at about 1500 to 2000 rpm but runs awful while it does. Purrs like a kitty at idle. Thanks
Sent from my SM-G889A using Tapatalk
1,739
Did you clean out the rails and lines from any metal particles ?
What is the commanded and actual fuel pressure when it stumbles at higher rpm?
diesel vein
Apr 2, 2011
15
3
The rails I didnt remove, the lines i did. The commanded and desired is together very close the entire time!
gmac32
288
3
bellville ohio
I have done quite a few and never had any problems. Is the tuning segments correct for that truck? I have seen that happen before with the wrong operating system
diesel vein
Apr 2, 2011
15
3
I double checked with the tuner ... they seemed confident the tuning was correct. It's tough finding good delete tuners any more..
9,903
149
I’d be looking close at everything you unhooked and unplugged again.
diesel vein
Apr 2, 2011
15
3
Reman lbz. I still have the green sensor from the old pump plugged in and the plug with yellow and black wires in the lbz fpr.
13,598
632
I've seen similar problems from a bad injector return regulator. They sometimes get contaminated when the pump fails and sends metal through the system.
Reactions: Bdsankey
diesel vein
Apr 2, 2011
15
3
The return regulator is what it was. Thanks a lot y'all. My day got a lot brighter when that got fixed.
