Line Seals
jlawles2
1,047
35
Danbury, TX
I had to remove and reinstall the transmission lines. I now have a pair of leaks at the transmission line to transmission cooler leak. I think it's just the o-rings. I have searched, but did not find any information for the o-rings.
The cooler is a Setrab (?) but it uses the standard GM lines. Anyone know the GM part number or what size o-rings to use?
jlawles2
1,047
35
Danbury, TX
Anyone know what o-rings go in the quick connect on the transmission cooler?
I don't think they would be different, but it is a Mike L cooler.
15,686
They are the same o rings as the stock fittings use. My fittings are made by Jiffy Tite; the same company that make the GM fittings.
jlawles2
1,047
35
Danbury, TX
Mike, thanks for the info.
Is there a special material for those o-rings or is it just a standard nitrile or viton? Also do you know what size they are?
