Lbz water pump part number
rg3whitelbz
Jan 19, 2013
166
Maryland
Hey can someone let me know which ac delco part number I need for a stock replacement? My searches show either 252898 or 251748. It looks like both come with a new cover. Thanks in advanced.
rg3whitelbz
Jan 19, 2013
166
Maryland
Zf I'm not sure. I'm done beating on the truck and its a 90 mile a day daily driver so I don't want or need anything welded or aftermarket. I'm open to suggestions though
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
It's not welded or anything performance. I thought I read lbz water pump impellers are plastic and the earlier ones are metal. Not that the plastic fails I just would feal better about a metal impeller
rg3whitelbz
Jan 19, 2013
166
Maryland
O ok I see. I knew there was a difference between lly and lbz pumps. Rock auto lists both ac delco part numbers mentioned in my op and I just want to make sure I get the correct one. Merchants isn't that far off in price considering it comes with the gaskets also.
02Dmaxdually
May 16, 2011
41
Havelock, NC
12637105 is the correct part number. The factory water pump had a plastic impeller on it, replacement ac delco pumps have a metal impeller on them and the part number listed you should be receiving the water pump mounted into a new housing.
LB7/LLY water pumps came factory with metal impellers on them they are also smaller than LBZ/LMMs (not sure on LMMs) as well as the water pump housing on a LB7/LLY is smaller than a LBZ/LMM
SoCalMike
758
SoCal
I just got this from merchant automotive today.uploadfromtaptalk1426118288996.jpg
