lbz vs lly rails
dracing70
SH--- GETTING EXPENSIVE!
Jun 12, 2007
1,210
45
mantua, oh
whats the difference if any between lly and lbz fuel rails? and if there is a difference can lbz rails be used on a lly?
13,597
628
LLY rails have the rail pressure sensor port on the top center of the passenger's side rail. LBZ rails have it on the rear. The fuel line connections are also different. On the LLY, they are just like the injector end, but the LBZ has a sort of collar that comes up around the end of the line that the nut threads onto. You'll see what I mean if you look at one.
You can run them, but you would need to get new lines and extend your rail pressure sensor harness.
dracing70
Jun 12, 2007
1,210
45
mantua, oh
thanks josh. can the pressure sensor be eliminated in order to utilize that port as another supply????
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,322
359
Central OH
Ecm needs to read pressure from somewhere. Not sure if it would be possible to put a sensor where the FPRV is....
13,597
628
No, you have to have a pressure sensor somewhere in the system.
13,597
628
PPE makes the FPRV port a supply in their dual CP3 kits for the LBZ and LMM. I suppose you could do the same for the rail pressure sensor and just put it in the block they use to relocate the FPRV if you wanted to feed each rail with one pump instead of running both into one.
TRUBBS
461
Not to HighJack but what about Lb7 to LLY rails?
Reason I ask is I RacePlugged mine but now am throwing low RP code again
dracing70
Jun 12, 2007
1,210
45
mantua, oh
Bottle test. And if it's a lb7 check the distribution block in the middle. Isn't there a fprv on that block on a 7???
TRUBBS
461
mines an LLY, but i have a set of stock lb7 rails off a core engine i was hoping i could use if needed.
im going to bottle test either this week or next when i install the lift pump/fuel system
