Lbz up-pipes
Yngdmax92
962
Hey guys,
I just had my up-pipes balloon. Literally bent the flanges of the up-pipes. Stock fuel truck with Danville turbo. Anyway to prevent this?
3,681
236
Lower drive pressure, lower EGTs, or stronger up-pipes.
Since lower drive pressure usually means turning down the power or buying a new turbo setup, getting stronger up-pipes is an attractive option.
Sent from my Cat S60 using Tapatalk
Yngdmax92
962
I wouldn't think a stock fuel truck has the potential to do this. It's just a stg2 3794 and stock fuel. Do vgts really create this much more drive pressure? I thought by me getting a larger vgt it would flow more air helping relieve drive pressure. Making 35-37 psi of boost.
Dozerboy
4,811
393
TX of course
You’re probably too aggressive with your Vane table producing too much to drive pressure. Only way to know is to get a drive pressure gauge after you get the truck fixed.
4,953
^^this.
Yngdmax92
962
Corbin, can you post up that pic plz?
Yes, Danville tunes. This tune is the turned down one, because when I asked for more it drained rail pretty good lol oops.
Trucks fixed already too. Just drill and weld a bung in one of the up pipes?
Get some copper brake line and coil it to a guage or you guys have a better idea?
clrussell
pro-procrastinator
Sep 23, 2013
5,909
364
Yngdmax92
962
Vanes definitely aren't stuck, turbo has less than 1000 miles on it. No boost leaks.
