LBZ P0777 after tires spun?
LBZ_Baker98
207
Texas
LBZ P0777 Limp
I have read a few post on hear about the p0777 code and and i have seen a couple people ask if the tires were spinning when the code was thrown. Usually peoples response is "no" but in my case my tires were spinning. Its a 07 LBZ with 118k Miles. its only ever limped 1 other time and it was when i didnt let the trans warm up (at all) and hammered it on to the hwy! I was in my 60HP tune and turned out from a red light in a hurry and got on it, the out side tire broke loose and went to spinning and smoking and rpms went way up, i let off just a little and got back in it and it limped. P0777 and P0700. I believe i was only in 3rd gear when it happened i was going about 35 or 40 miles an hour at most. I have hammered it in my biggest tune (120HP) multiple times since and it has not limped. Could it have thrown this code because the tires were spinning and it just got confused or is my transmission completely toast? The code had no issues clearing and has not come back! Thanks in advance for everyone's help!
LBZ_Baker98
207
Texas
You are full of shit.:roflmao:
Look I understand you know your stuff when it comes to transmissions but that doesn't give you the right to sit here and call me a liar. Don't get me wrong I have played around before and done a burn out. But in this case I wasn't messing around. So no I'm not "full of shit". I thought this was a site to help people. People come here looking for advice from you because they trust you and just like me they realize your the best in the business. It doesn't seem right for you to just come here and be demeaning to those people/ potential customers. Sorry that some people don't know as much about transmissions as you but you weren't born knowing what you were doing you had to learn just like everyone else. Your a transmission specialist. Not a psychic so don't go off accusing people of being liars. Have a good night and thanks for the help.
4,967
this code doesnt set from taking off from a red light and giving too much throttle unless you keep in the throttle through your 4th gear shift as the tires are spinning. hence, your fibbing.
do a search on here, this code has been covered many times. you will get the possibilities of what you need to do very quickly. :thumb:
LBZ_Baker98
207
Texas
I said in my post "I believe I was only in 3rd gear but I'm not positive" it may have been in 4th gear regardless. I WAS turning from a red light. I was late for work. The tires DID spin I let off a little and got back in it and it through the code. All I was asking for was a yes or no answer if the tires spinning could have caused the code
4,967
its not that simple
CaptPhil
1,012
Delaware
Wait, your 120 tune will spin the tires in 3rd gear? Damn, super spicy tuna.
Sent from my SM-G900T using Tapatalk
DMAXchris
It’s only temporary!
Apr 28, 2009
2,274
Natrona Heights PA
I got the jackpot code from doing the same thing. Well except mine was completely on purpose. Needless to say my trans was out a few days later getting the clutches replaced.
