LBZ electric fans ?
Kentucky DuraMax
Gearhead
Dec 30, 2012
19
Hey guys I was just wondering if anyone out there is running the flex lite dual electric fan on their LBZ. I know they only make them for 01-05. Why wouldn't it work on the LBZ? I have seen these ran on some pretty badass LB7's that are multi-purpose and seem to do fine. Any info or insight would be appreciated.
56taskforce
1,074
51
I personally have never liked electric fans for anything but a dedicated drag racer or in a swap situation where you are left with no other choice.
Because I plan on running twins I will probably run electric fans on a large remote oil cooler.
Electric fans are defiantly useful and have their place but diesels are low RPM high torque engines so the parasitic HP loss to the mechanical fan, other than an all-out competition doesn't merit the change.
Dozerboy
4,811
393
TX of course
Why is that there isn't a down side to elec. fans unless your towing heavy in hot weather? The fan isn't a huge draw on power unless its locked, but when its gone its noticeable.
Elec. are great for keeping the AC cooler in traffic/idling in hot weather. Better mileage, no "morning sickness" and more power/acceleration.
henery97
206
Nebraska
I'm planning on doing the Taurus fans when my LBZ goes back in.. They move almost as much air as the stock fan..
56taskforce
1,074
51
I guess I just follow the kiss philosophy and I do tow this.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
33
Lexington, Ky
Whats the biggest size dual fans can I run on the radiator? And what about on the front side of the intercooler
prostreeter600
Street rodder
Jul 18, 2010
893
Dallas Tx
I personally went with FF Dynamics rated at about 6000 CFM . I got the ones with the Shrouds. Super clean looking install and for about the same money as the Flex lite setup . Check em out I think you will like em .
Harbin_22
3,858
Southern Indiana
I've been running flex a lite fans for the last 3 or 4 years with zero problems. I don't tow heavy by any means so I don't have much input there. As far as any kind of normal use of the truck, they go unnoticed. I have mine on a switch too so I can flip them on setting in traffic or if I have been out beating on it to help cool trans temps faster. All you have to modify is the top mount. And the tcm bracket doesn't fit right. Really don't know why they never came out with a kit for LBZ or LMM. Not a lot has to be changed
kivetts04dmax
May 20, 2010
742
Boonville, MO/Pendleton, CA
I modded my top bracket and the TCM bracket, I didn't want to drill into my fuse block so I bolted the supplied tcm bracket on and marked it so it would clear the heater hose (van hose/thermostat housing) and cut it down and drilled another hole using the hole I drilled and the stock hole to mount the TCM in two of its three holes.
jgallagher450
Oct 3, 2014
11
Graham, Wa
I may be a little late here but I have the 284 Flexalite fan setup on my truck, have had it for a while and i got a bracket kit for the 01-05 and the side mounts worked fine. i took the long piece that bolts on top and just flipped it over and bolted it to the old fan shroud hole and it works fine. Ive towed 8-10k in 100 degree weather on 35s and the hottest i got was 213 degrees
kivetts04dmax
May 20, 2010
742
What all has to change to mount the 05 flex a lites to the lbz?
I can get you some pics but pretty self explanatory..everything fits the same except the top mounting bracket which I just marked and drilled 4 new holes and a few holes in the top of my radiator, and I cut the top on the tcm bracket off and mounted my tcm a little lower on it..not bad at all
