LBZ: LBZ compression tester
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Most diesel compression testers won't have the tip for LBZ+'s. An LLY/LB7 piece won't work.
Kent Moore PN J-35667-8 is the LBZ adapter. It works with either Kent Moore or Mity Vac but not the General (Harbor Freight).
Casper's compression today was 320-360, most 340.
slowlmm
Mar 2, 2008
2,582
45
so cal
Find out what P/N your's is. Maybe mine is "dated".
ok next time im over at jasons ill look. i kow it was like $27 only. came with 2 adapters a longer and a shorter one tht was the thread pitch for our trucks. as well as many other for other trucks:)
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
59
Norco, CA
Or have Jason go look ;)
LBZrcks
Jun 2, 2007
5,297
12
SoCal
:witch: Do I have to? :rofl:
I'll check for the part # in a few.
The Kit we used had a the adapters but, not sure if they are indeed different (thread pitch wise) from LB7/LLY to LBZ/LMM. The only hard part was that we couldn't tighten the adapter very tight since it wouldn't fit very well in the hole/slot. It would still hold the pressure though
Kat
Aug 2, 2006
17,899
13
59
Norco, CA
Yep :frog: or face my broom :joker:
:rofl:
Kat
Aug 2, 2006
17,899
13
59
Norco, CA
Here is another number. Thanks Robert :hug:
