LB7 Wehrli Custom Fab intake kit
kubitza123
Sep 19, 2016
144
Texas
Well I got my y-bridge and turbo intake horn on the truck. Got everything else together and went to install the MAP sensor and it won't work.
Mine is a Cali emission truck which I just fully deleted . I'm assuming the Map sensor from a non emission LB7 is what I need to buy to fit the new intake setup ?
I would have called them but they aren't open so figured someone here may know.
Current one doesn't have a bolt hole for mounting and has a nipple with vacume hose coming off it.
Looks like I need a sensor with one bolt hole and a nipple on the bottom of it with a seal.
JRein
Aircraft Mechanic's Hero
Sep 26, 2015
212
LRAFB, Arkansas
Yours didn't look like this?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
kubitza123
Sep 19, 2016
144
Texas
No , my switch is the same but brackets different since Cali model i guess. I built a mounting bracket and found a tight fitting hose to make a grommet.
Good to go now.
