lb7 swap need help
Lil LB7
Feb 9, 2015
11
ontario canada
hi guys im in the middle of finishing my 1500 rcsb lb7 swap and the electrical is kicking my butt. Im getting a p0612 code and cant figure it out. I heard there is a ign relay mod to fix this. If anyone knows about it help would be appreciated
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
That code is because the ignition 1 relay for a gasser is triggered by the ignition switch, in a diesel it is triggered by the ECM to power the FICM. You either have to use a diesel fuse panel, or you can install a separate relay outside the current fuse panel for the ignition 1 relay, and set it up to be triggered by the ECM.
1,625
Yeah, Ferm meant the underhood panel.
BTW, a huge "thank you" for the mount pics. You helped me get over a roadblock on my half ton.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Yes, the underhood fuse panel. I know Eric installed a remote mount relay on them so he could retain the burb fuse panel and keep the code away.
