LB7 miss
lutzjk913
1,585
107
groveport, ohio
Ok guys. Sons truck is having an issue.
Stock motor. LDS 45 Sac injectors
Had a bad misfire/lope and pouring black smoke. Cylinder 3 injector is maxed out on balance rate. Shop diagnosed it as a bad injector. They could cycle the injector off and the fuel knock and smoke would go away. It would idle fine.
Called LDS. Started the warranty process. They got the injector back and said the roller was bad if I recall and replaced it. Sent me a new injector and the truck does the same thing.
Shop did a compression test on the cylinder and it came back good. Shop also swapped in a good ECM and FICM and truck still does the same.
Replacement injector was sent to S&S and tested fine.
Also under valve cover harness was replaced.
Shop has also ohm tested the harness. As of now they are going back over the harness a second time checking things over.
Any insight guys on where to go?
Thanks
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,327
364
Central OH
You probably don't want to pull the injectors back out, but maybe have it and a good one tested? Purrformance Diesel is reasonable
1,750
Make sure they are pulling the right injector. Cylinder number VS firing order. I've seen that mistake. Some scanners don't show the right cylinder number that corresponds to the one it's turning off. Tech2 is correct but EfiLive and maybe even snap on has shown this issue. They might need to prob the harness to verify the actual injector they are turning off that stops the noise. Then they can pull that one and not whatever the scanner says.
Reactions: wydopenLb7
lutzjk913
1,585
107
groveport, ohio
Passenger bank. Second cylinder back.
Not sure on what scanner. I believe it’s a snap on.
Also. The under valve cover harness was replaced. Also left that part out. My bad.
lutzjk913
1,585
107
groveport, ohio
Update
They swapped cylinders 1 and 3 and the issue stayed on 3. Rules a injector out
Shop is recommending replace both engine harness now
1,750
Update
Both?
A proper shop would be able to ohm out the wires and test if it's the harness or not. Could be the FICM, could be just the pin in the connector. If the harness is bad they should be able to show you exactly where in the harness. I hate parts swappers
lutzjk913
1,585
107
groveport, ohio
I’ve been all over the place and forgot to update this
I gave them a ficm to test.
And yes both harnesses. Supposedly both of them have been ohm tested twice and they can’t find anything.
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,034
245
At Da Beach
Could the return line be clogged up and causing issues? I think I remember something along time ago about this same issue.
Dallas S
485
33
Alberta
Just because it ohms doesn’t mean it will pass a load test. See many guys get burnt with a multimeter…
Reactions: 2004LB7
1,750
Unlikely to affect only one injector. The LB7 has that hard return line that connects all the injectors under the valve cover before exiting. If it was clogged then multiple injectors would likely have issues. Plus the LB7 is not as picky about the back pressure as the later years. Infact they can run without any back pressure. I believe the incoming pressure just has to be at least 1200 psi above the return pressure to operate the injector
