LB7 injector HP line socket info
3,682
236
How is everyone doing LB7 injector lines without a crows foot? Does everyone just guess on the torque, or use the old pull-on-a-wrench-with-a-spring-scale trick? I always use a crows foot to tighten them up, works really nice.
Having the right tool can make all the difference, though. Looks like that job would've sucked without it.
kidturbo
Piston Tester
Jul 21, 2010
2,333
1,103
Somewhere On The Ohio
www.marinemods.us
Kinda like when I ask my other farmer buddy when last time he used a crows foot.. Said last time he changed an injector on a tractor.. lol. Guess for certain jobs they are the primary tool of choice. The standard open end version scares me. Brings back "painful" memories..
1,755
Did my first set with the crows foot. Then after that I did them by feel with an open end wrench
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,330
365
Central OH
I'm with you, a 6pt crows foot is most times easier than a wrench anyway.
1,611
19mm injector socket like this one:
https://www.toolsource.com/misc-c-318/19mm-injector-line-socket-p-241929.html
You can use a 3/4" one, too.
I bought mine from my Mac dealer on my route. ;)
ironmax
chock full of goodies
Jul 7, 2010
502
27
Col. Ohio
I was going to ask that exact question?
Sent from my SM-J260A using Tapatalk
1,611
I copied the posts concerning the injector line socket into their own thread in Tool Crib.
4,963
i use a good crows foot on a torque wrench. thats about the only time i pull mine out. my o2 sensors on my gas rigs i just tighten by feel with a reg wrench.
bigboybuilder
Nov 3, 2019
for 15 years worked in automotive ( transmissions mostly) and then moved into industry for the last 25. if a bolt had/has a torque rating I use a torque wrench 50inlb to 3,000ftlb I never compromise. a Graco air over pump using a uv cure sealer is a perfect example to much torque on the gland nut and they would only last a week, with the proper torque over a year. the person that was rebuilding them said " it's a big nut so it must be real tight".
