I've done a little research on the lb7's vs lly heads and I thought about replacing my lb7 heads with lly when I do my studs and gaskets to keep from having injectors issues down the road. But I read it won't work. What all is included to make this not work? Injectors different? Could not just change the plugs on them? I know the heads will bolt in place. So has anyone ever done the swap before?
