Well this is the elusive LB seven fuel pressure relief valve. It's so special that the dealer wants about $700 for it. It's only sold as part of the fuel rail junction block. None of the shim kits or fuel race plugs available will work for the LB7 I don't believe. (Correction. PPE has a plug. Not sure if there is a shim kit for the LB7)
As you can see I have disassembled the valve and I am going to shim it with a few nuts, to improve spring tension.
Total cost zero dollars! I had some on the truck.
I have heard lots of talk on the forums about the LB7 fuel pressure relief valves and how they weren't prone to fail. But this one definitely did fail. I confirmed it two separate ways.
