Hi guys,
Had the truck scene new a 2001 LB7 dually. Just did the injectors on it, the originals held for 160,000 miles!
I lost an injector with the typical white smoke and un intentional "loop tune" at idle.
Before the swap she could tow anything up any grade under any conditions, best running truck ever, however... I swapped out all 8 injector tips with 30 "over" ones. she was running fine for a month, I didn't tow anything with the new tips in... yet. I did a series of trips picking up some project cars "not the heaviest thing I've towed by any means".
Went into safe mode "fuel leak" when loaded up/ spooling going up some steep long hills. She would slow down as usual and id pull over and clear the code and coast home...
Its not a fuel leak on the block, I replaced the fuel lines running to the fuel computer along with a few other lines running ontop of the engine.
Am I not delivering enough fuel to the new 30 over injectors when spooling with heavy loads?????
