Hey, my friend just put a late, 2006 LLY engine into an LBZ, wont' start, getting cam/crank errors. I've read these are basically detuned LBZ's until they could get the programming thru the EPA. On that note!
Is the reluctor the 57 tooth or do they use the LBZ 58 tooth? What crank do they use? Are they LLY heads or LBZ heads? Will the injectors have to be swapped out?
Sorry, I'm not there to help him out and he's not good at figuring stuff out. TIA.
