Is it more then its worth... time and $ to do LB7 in a military HUMVEE?
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,040
246
At Da Beach
I’m about to dive into an H1 myself. We are doing a 6.0 with a tvs1900:swap. Just make sure your H1 has a 4l80 from the factory so you don’t have to redo everything.
Mogman
341
17
Papalote, TX
I did a LMM swap almost 3 years ago, definitely worth every penny and every ounce of blood (there will be plenty!)
In the middle of the project I swore I would NEVER do THAT again.
I just picked up a 07 LBZ for my next conversion, I think the LBZ is the best as more of the stuff I want like cruise control is in the ECM, I plan on using the GM inst. panel in this conversion, the post LMM engines get too tall, the LP5 would be practically impossible to install.
Also the Basic or A1 HMMWV is by far the best to start with as they have the lowest ratio diffs (2.56) and do not ride like a brick on a skate board like the A2s and ECVs do. (ECV is the worst with the 3.07 gears as the big GM transfer case has been documented multiple times to handgrenade)
Here is the link to my build thread which I am very glad I did because I suffer from CRS big time.
