I'm pulling codes U0140 U1041 and U0100 all loss of communication bcm ecm and ebcm I believe are what they are for ......I've cleaned all grounds ....checked harnesses ....all looks good only thing I haven't been able to do is actually fix it ..truck will run for 5-6 minutes then all the gauges drop out except for battery voltage ....sent it to a diesel shop near me for 6 MONTHS replaced bcm and programmed and tbcm .....told me they couldn't figure it out ...has anyone had a similar issue .....any advice on diagnosis thru means of probing pins etc. Would be useful because I don't have access to a fancy scanner
