Help: Injector Wiring Harness
9,903
149
Does anyone know if the colors on the wiring for the injectors are the same at the injector plug as where it goes through the main harness plug? I'm tapping into this harness and I would like to do it at the main harness wiring as it is easier to get to and repair if it ever corrodes.
Thanks
9,903
149
Also, can someone tell me the pin # for the #2 injector wiring at the above mentioned harness plug mounted to the valve cover? Is it in the lower or the upper plug?
13,598
632
Dale, I would recommend you get a multimeter and do a continuity check at the injector plug and the bale connector to find the correct wire.
9,903
149
I can't find my damn meter Josh!:eek:
It might be in my tool box locked in Simon's garage.:(
13,598
632
No stores open you could get a cheap one? It would be a lot better than guessing based on color. Sometimes GM uses the same color wires for different things. I'd hate to tap into the wrong wire.
9,903
149
Roger that Josh. I'll get it figured unless someone answers my question first!
Cougar281
1,755
214
St Louis, MO
According to connector pinouts, the #2 injector control wire should be the Light Green/Black wire in position A4 of the larger of the two bale connectors.
13,598
632
What wire is it telling you to tap into? I have a meter and I can check my harness.
13,598
632
I went out and did some testing for you. I wasn't sure which wire on the injector #2 plug you were looking for, so I just checked both. I saw one purple and one green. The picture shows which terminal on the bale connector showed continuity with which wire. I could only really see which wire was coming out of one of the terminals and it was the one that showed continuity with the green wire. The wire was green with a black stripe. I tried to look at the other wires, but they were very hard to see. I think the middle one was black with a white stripe and the top one was purple, but I'm not sure about those. Here's a pic with the terminals labeled. This is the lower bale connector.
attachment.php
9,903
149
Thanks Josh. I found my meter and did the same testing and came to the same conclusion.
You must have nothing but time on your hands today!!:D Don't you have a truck to build still????:joker::D
J/K Thanks!!:)
9,903
149
Thanks-that was bang-on!!
13,598
632
J/K Thanks!!:)
I don't have anything going on right now. The motor is pretty much together. I'm just waiting on turbo stuff.
9,903
149
Well you should have packed yourself into that box Josh and helped me put that pipe on!!:D
13,598
632
I think shipping would have been a little more expensive... :rofl:
