There is no special Loc-tite
The red loctite is what you are suppose to use
the gel works 3 x as good as the normal stuff ( if that makes it special)
Like subman Said though GM spec say leave it untill the loc-tite is cured before adding coolant (12HRS MIN ) we have done it with sucess in less than that but that was a rush case
By advice is make darn sure the sealing area in the heads is clean....Most probloms are because of this
I use a barrel brush conected to a cordless drill and clean out the old loc-tite from the heads ( it needs to be spotless IMO )
It is a fair bit of work and takes me longer than 10hrs,But Paint is a better mechanic than I:baby:
How do you know its a cup and not the head gasket? If/when you look at the cup it isnt that hard to tell it's leaking,sometimes they are craked also
