Ive posted a few threads about leaking injectors and a coolant pressure issue after i did my injector a while back. Finally tore into it today thinking if the injector cups look good ill go down to the head gaskets. It was injector cups. Numbers 1,3, and 5 all pulled out with the injector and the crush washer on number 7 was canted a bit allowing combustion gas to get past it. Valve covers full of white goo. I stopped working on it today when i stripped the return line bolt head on number 6 , tips on getting that out would be appreciated . i keep hearing about installing injectors the "proper way." This was my first major job and took me an entire week because i took my time with everything to do it right. So id just like to hear what you guys have to say. How do you set the crush washer in the cup and make sure its straight? Since my cups are out can i install the cup with the injector inside? I got the process down just looking for those little "tricks" you guys have, treat me like a dummy
