In need of custom bolt
AZlml
278
32
Goodyear, AZ
Anyone on here that works at a machine shop have the ability to make a custom bolt? I'm looking for (2) 3/4-24 x 2.75" grade 8 hex head bolt with no shoulder (has to be threaded up to the head). I cannot find such a thread pitch for a 3/4 bolt anywhere, but taps and dies are all over the internet for 3/4-24. Local machine shops won't bother calling me back for 2 custom bolts, I guess it's not worth their time.
4,953
maybe try allens fasteners? they dont show them on their website but might know of where to get them or even order them in?
N2BRK
1,906
231
McMaster is my local go-to but they don’t even have that pitch.
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
Get a bolt with a long enough unthreaded shoulder. Cut the threaded part off, and then run the die down the bolt.
AZlml
278
32
Goodyear, AZ
I might give this a try, never thought about that and it'll be fairly inexpensive.
Called them with no luck as well, we buy tons of random stuff at work from them but this stumped em.
I'll check them out just to see if such a bolt exists somewhere without being custom made but so far it's not available.
fl0w3n
508
25
What’s it for?
I’m assuming it’s not possible to retap the hole to a common thread pitch?
4,953
How much torque do they need to see? Grade 8 bolts are roll formed threads which is much stronger than cutting them via a die. If it’s not a super integral part, I’d just cut them with a die.
1,748
I know Fastenal has a ton more fasteners then what there site shows. You will have to visit one of their store to see what they can get though. And if you find one longer you of course can cut it down but as James mentioned, the threads are rolled/formed not cut, and being you are requesting the grade 8 strength I would not cut them.
Also, it may be a good idea to explain to us what this is used for and maybe we can help you come up with better alternatives as that bolt size thread tpi is not a standard combination. The dies you are finding are not likely for bolts for any form of clamping fasteners but is more common in something like rifle barrel threads
