Hey guys, So if anyone has followed my project cracked piston build, I got it started up recently. It started without any issues warmed up and drove around fine.
Some background on the system.
Sump from the fuel tank to -8 to AD2-165 then -8 to 12mm cp3
The return is -6 from the cp3 to a return block with the injector returns then -6 back to the fuel cooler
the fuel rails have ported fittings, drivers side is .125 and the passengers is .062
This morning I started it up and it was about 20 degree colder than it had been every time it had been running. The issue was that on my EDGE CTS is listed the FRP at 23kpsi. So i pushed on the throttle a little hoping it would go down and it did until it reached what was being commanded.
When it warms up it idles about 1-2kpsi higher than what is being commanded.
long story short after researching and testing the cause is the lift pump(AD2 165). at the moment I am not sure what the pressure is in the line just that the pump is still at factory stock settings which should be 8-10psi. I have ordered a gauge so I can plumb it into the feed line and see what it is.
My question is when adjusting the lift pump what should I be looking for, obviously I dont want my new CP3 to be building 25kpsi at idle. Should I adjust the pressure down until the FRP matches the commanded FRP? but keep it high enough that it doesnt drop to 0 at WOT on the race tune?
Wikid
Wikid
