Hydroboost replacement question
paoutdoorsman
Duramax Fan!
Mar 27, 2009
159
South Central PA
For those who have replaced the hydroboost unit; is a new gasket between the firewall and hydroboost needed or does the original tend to be re-usable? I have a new hydroboost here to install, but neglected to think about ordering a gasket.
paoutdoorsman
Duramax Fan!
Mar 27, 2009
159
South Central PA
I wasn't sure if it was rubberish and reusable, and paper that would be destroyed with removal.
Also, is there a gasket between the master cylinder and hydroboost unit?
ryan415
Oct 24, 2012
371
860
If I remember correctly its just a small piece of foam and there is no gasket between the master and booster
redrob
Apr 6, 2013
41
Western Wa.
On some gm rebuilt hydroboost units, the builders fail to include the important push rod and retainer clip for proper operation located at the front of h/boost- you have no pedal without this pushrod! If it's missing,you will have to transfer it from oem unit.
