How much should jesse spray my old Zf6?
How much spray on the stock engine Zf6
  • None: he can do it alone
    Votes: 3 5.8%
  • A little in 6th
    Votes: 3 5.8%
  • No jet in 5th and 6th
    Votes: 6 11.5%
  • All the spray from the light to the stripe
    Votes: 40 76.9%
  • Total voters
Yngdmax92
962
I'm going out on a limb, and going to say you can kiss the 10 mark with a fuzz better set up! Your close and you said your trans was breaking your b*lls shifting in the later gears. Get it the 10 mark on stock motor and fuel. Spray it to get that one pass that will make the untouchable record :happy2:
MarkBroviak
DMax Junkie
May 25, 2008
2,076
365
Danville Indiana
I'd put the nozzle in the air intake in between the MAF sensor and the turbo for best results and spray the whole way. Start with a 50 jet and see what it gets you.:thumb:
5,021
50 shot hmm I don't know about a shot that small lol
if you have alot of fuel left to be burned, a 50 shot is more than 50hp lol.
if you want to be a hero, -4 line straight into the intake. thats a "pass tech ghetto fog" :roflmao:
3,683
236
I like the idea of a momentary switch on the shifter (or the steering wheel) so you can spray once you hook. No point wasting nitrous if you're already spinning the tires.
And you can run without a jet, but that'll empty the bottle faster than you might need, which just runs the cost up. Of course, if you are only going to do a couple passes, the time savings to hook it up as James suggested ("pass tech ghetto fog" LOL!) might be worth the extra nitrous you use.
SmokeShow
6,818
Lawrenceburg, KY
I'm curious, how much is nitrous? Not the kits and whatnot. I mean the gas. Just how expensive/cheap is it? Like a normal size bottle. How much to fill it? Roughly how many passes could you get out of one?
ZeroGravity58
1,391
47
Maryland
Roughly $5.00 a pound last time I bought it...it's been alittle bit tho. Bottle size would be 10 or 15 pound bottles. How many passes depends on how big a shot. When I was running a 200 shot on a gasser about 4-5 passes before bottle pressure started to drop on a 10lb bottle.
5,021
with the "shortage", its anywhere from 8-11 bucks a pound here in az if you can find it. 10lbs bottle lasted us about 4-5 passes as well with a 175 shot.
LBZ1991
Nov 21, 2014
215
Winfield, MO
I'm just now finding out about the shortage. So far no one in Missouri has any. Everyone said they've been driving to Texas :spit:
