LBZ: Horrible noise in 4x4
DuramaxTireSmoker
Jun 8, 2010
339
SW Florida
I'm working on a 06 LLY. I know the front driver side wheel bearing is bad, and i havent got to replacing it. In 4wheel drive i've got a horrible beating noise starting around 10mph and it grinds so bad it slows the truck down. Do i need a new front differential? I tried a different transfercase and that didn't do it. Could a wheel bearing cause this much noise? I need to do some diagnosing but thought i'd ask your opinions..
Kappa9012
MAN.... I Broke it again.
Aug 5, 2008
694
Peoria Il
pull the cover or at the very least the drain plug on the front diff and see what comes out. not sure if engaging 4 wheel drive with the front drive shaft out would help diagnose a bad xfer case or not.
S Phinney
4,011
Quncy, Fl
Hubs can make some terrible noises. I bought a truck from a guy and I wouldn't complete the deal until I changed the hub because it was that hard to believe it was the hub that was making that noise.
ryan415
Oct 24, 2012
371
860
Sounds like you lost a pinion bearing. Gonna have to drop and split the diff in half. They're pretty easy to rebuild
ryan415
Oct 24, 2012
371
860
I belive so. There should be no movement in the front yoke other than rotational obviously. lol Definately sounds like you're gonna need some bearings and gears
DuramaxTireSmoker
Jun 8, 2010
339
SW Florida
found one at a salvage yard but thanks Todd.
What's the trick to removing it? I have all the bolts out but I don't see how its gonna come out. Do I need to remove the centerlink?
