LB7: Home heating oil gaff
briencolgan
brien colgan
Jan 26, 2017
85
Ithaca, NY
I did something brilliant with my 03 duramax. I came across 300 gallons of free diesel in a metal tank. And I put it all in the truck . And things were good until the last 40 gallon fill.
I watched the fuel turn black going in and thought to myself this is a bad idea. And predictably I’m chewing through filters every 50 miles.
I’m probably on filter 6. (I get just over 200 miles per fill up) I was figuring eventually after enough filters, the problem would go away. On this particular truck dropping tanks is doable but a pita due to an aftermarket box that’s welded on.
Am I gonna have to just suck it up and remove the tanks or do you think after enough filter changes the sludge in the tank will be eliminated.
I’d rather spend another couple hundred on filters versus dropping the tanks.
1,605
Moved to Fluids and Maintenance, b/c after using that fluid, you're going to be doing a lot of maintenance....
AZlml
278
32
Goodyear, AZ
Even after seeing it turn black you kept going? And after the first filter change at 50 miles you still kept going?? Free "fuel" is not free if you cause thousands in damage...
briencolgan
brien colgan
Jan 26, 2017
85
Ithaca, NY
I figure the filter is doing its job. That’s why. Am I missing something? Can impurities get past the filter?
1,741
Filters catch a percentage of particles based on their micron rating and efficiency. So some will get past the filter. How much? Depends on the filters you are running. The more junk in the fuel the more will make it to the pump and injectors
I would drop the tank and clean it out fast. LB7s are the least tolerant of bad fuel. You can trash a good set of injectors in a few miles like that
