High Flow OEM replacement Up-pipes!! NOW 50 STATE LEGAL!!!!!!!!!!!!!!
Dan@PPE
Diesel Enthusiast
Aug 8, 2006
2,570
So Cal.
Looking for lower EGt's and less drive pressure for your 01-2015 Duramax???
Our new 116120000's are a bolt-on, high flow upgrade to replace the factory GM up-pipes.
Constructed from the same 11ga stainless steel and uses our aircraft grade bellows, just like our high flow exhaust manifolds and up-pipes.
These are designed to work with the OEM manifolds and are NOT compatible with our high flow exhaust manifolds. Currently these are available without the EGR riser (racing applications) but will be available soon with the EGR riser and hopefully 50 state E.O. exemption (in testing right now).
Retail is $499.99, street price of $449.99, however I am going to run a special for DD members. Please pm me or call me for the special offer.
link for more product info...
http://www.pacificp.com/store/index...ducts_id=522&zenid=vod5qem0tc0eg6mbh73mcaf527
Dan
714-985-4825
Dan@PPE
Diesel Enthusiast
Aug 8, 2006
2,570
So Cal.
I would say only single turbo only.. Our thoughts are... If a customer has already decided to go the compound/twin turbo setup, they most likely are looking for quick spooling, maximum performance and air flow that only our Hi flow exhaust manifolds and up-pipes will deliver. However there is a nice increase in flow with just these... Just not as much as the Combo manifold and up-pipes...
Try and convince me otherwise.. ;)
4,999
valid point!
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
Tip of the hat to you guys at PPE, its about time you guys made something like this! These will be a perfect compliment to a tuned stock turbo, or even a larger drop in performance turbo.:thumb:
I know if these were available 4 hears ago, that's what I would've gotten instead of the complete manifolds/uppies set
Dan@PPE
Diesel Enthusiast
Aug 8, 2006
2,570
So Cal.
Thanks guys!! :hug:
Some more good news! :D
I just confirmed these carry a limited LIFETIME WARRANTY!!!!:thumb:
Dan@PPE
Diesel Enthusiast
Aug 8, 2006
2,570
So Cal.
:hello: This is just in.....
Our high flow O.E.M. style up-pipes are now 50 state Emission legal!!!! (’01-’15) - E.O. No. D-701-16
These are available for the following years/applications, they are 50 state legal when used on the correct application.
2001 CA and 2001-2004 FED (116120000)
2002-2004 CA LB7 (116120204)
2004.5-2005 LLY (116120405)
2006-2007 LLY/LBZ (116120607)
2007.5-2010 LMM (116120710)
2011-2015 LML (116121115)
Special pricing for ALL DD members!!! :thumb:
04chase
222
interested, when will they have egr available? looking to keep my dmax easily returnable to stock for smog reason. may do a drop in turbo in the future though .
bcdeutsch731
619
13
40
Illinois
Installing mine now! These are a very nice piece. I put the heat wrap on them.
