I'm going to guess that most if not all the problems are a result of the delete and tune
2004LB7 Well-known member Dec 15, 2010 6,395 1,756 113 Norcal Sep 28, 2022 #21 I'm going to guess that most if not all the problems are a result of the delete and tune
2004LB7 Well-known member Dec 15, 2010 6,395 1,756 113 Norcal Sep 28, 2022 #22 Chevy1925 said: has the throttle blade been disconnected or are the electrical plugs still plugged into it? its a known issue that if the truck is deleted and the throttle blade is still on the truck, the blade needs to be disconnected. Click to expand... first time hearing about this. never had any issues with mine when it was deleted and the throttle blade remains intact and plugged in Reactions: 08lmm72mm
R Ron Nielson Active member Oct 11, 2009 693 116 43 Berryton, KS Sep 28, 2022 #23 If the scan tool has both pedal readings, it might be interesting to look at them, you may have some information you can use to determine the problem. See here:https://www.duramaxforum.com/threads/throttle-position-sensor.967105/
Chevy1925 don't know sh!t about IFS Staff member Oct 21, 2009 21,178 4,967 113 Phoenix Az Sep 28, 2022 #24 2004LB7 said: first time hearing about this. never had any issues with mine when it was deleted and the throttle blade remains intact and plugged in Click to expand... I think it depends on the tuner from what I remember but it can cause his issues. There was a couple guys who had that issue on here before
2004LB7 Well-known member Dec 15, 2010 6,395 1,756 113 Norcal Sep 29, 2022 #25 Chevy1925 said: I think it depends on the tuner from what I remember but it can cause his issues. There was a couple guys who had that issue on here before Click to expand... well then I guess my tunes must be better then I give them credit
