So I have been getting a p0103 and p0238 although they are intermittent they come up more often than not. There is tons of black smoke at any level above 1/2 throttle and low power, boost levels are normal. I replaced the maf because mine was questionable at best. I have no intake air leaks and no boost leaks and wiring looks good.
The p0103 sets a few miles after startup most times and the overboost code sets on any moderate to hard run with like I said TONS of black smoke. It's disgusting and I don't even want to drive my truck it's so bad.
Anything I should check besides possible map sensor, it's plugged in and not physically damaged, any way to check it besides swapping with a known good one?
Could this be a tuning issue?
Any idea much appreciated.
