HELP Transmission
Chevy2005
Feb 5, 2024
USA
I have a strange issue when the truck will try to downshift to second and will go into a false neutral and then jump into gear and go into limp mode. I have got a "second gear incorrect ratio" code and a P0776. Is the transmission ruined? or do I just need a valve body
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,330
365
Central OH
Downshifting under power? I doubt the transmission is bad, p0776 can be bad if somethings broke, but if its still drives after clearing codes likely vb related
Chevy2005
Feb 5, 2024
USA
I think i just lost 4th gear. it will limp randomly and acts like the c2 could be bad. i suspect the valve body caused a tie up and broke my c2
Chevy2005
Feb 5, 2024
USA
im not easy on this poor truck either and its gotten progressively worse over the last week and every time it limps it has a P0732 code
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,330
365
Central OH
I'm not saying something broken is impossible, but check wiring and solenoids before ripping the whole thing out. Does it shift fine under light throttle? Stock transmission? Built? What parts?
Chevy2005
Feb 5, 2024
USA
im not sure what kit it has, previous owner claimed it had a ppe stg 5 but I'm way below the hp limit of that and having problems
