HELP No Shift Indicator Line, No Crank No Start
ZeroGravity58
1,389
46
Maryland
The only thing that will stop it from starting on the glow plug module plug is the can bus wiring. Try jumping pins 43 to 45 and 44 to 46. If these pins are not making contact there is no communication between the ecm/tcm and the bcm so it will not crank or start. If it doesn't fix it then thata not the problem.
  • LMMGPCM-X2.pdf
REED84
May 19, 2021
23
Have you had it ever show transmission hot idle engine and no start and no line indicator. This happened after I cleaned the plug to back of the transmission and plugged it back in?
drobin
Jan 9, 2022
So we may have narrowed it down to something wrong with the wiring going to the glow plug mod. Moving the wiring around brings back the line and it will start. Still working to figure out what in the world is pinched or broke or shorting :eek:
Hello Carolyn I also have a transmission issue showing up with a glow plug issue what did you do to fix this?
Dave
