OK, I had a pull last week and did great! everything was fine I drove home with no problem and it ran great. the next day I went out to start it and wow what is that noise! As soon as I fired it up it sounded like a sever heat shield rattle, only there is no heat shield? the sound went away as soon as the trucks oil presure jumped to 60psi, less than a couple of seconds, then the noise went away. Well I changed the oil and put lucas in, changed the fuel filter, loaded stock tune and it seemed to get better, uh nope! I decided to drive it to work and holly Sh!* when I got to work the noise was so bad it sounded like a air hammer on a piece of tin. The thing is as soon as you touch the throtle just a tick the noise goes away I checked the injector ballance rates and they never went more than -4 to 1. The truck still runs great, no miss, no oil spewing out, no real signs of piston crack? The problem is the noise is so loud I cant tell exactly were its comming from? every were I go to listen and try to find the culprit, it sounds like that is were its comming from, under it, over it, drivers side, pass side, tranny, turbo,AHHH its terrible! I do have 60% over injectors, Oh yeah I keep getting a p2610 code and a p2510 code WTF? any one have any ideas? or seen this? thanks in advanced
