Headgasket question
815
Speaking of needing help. I have a Question about Head gaskets on a built motor if any one can help?
LBZ .020 over bore with Racecast pistons. Forward edge I have .008-.009 Piston protrusion and .006 on the rear side directly over the pin. Running standard head studs if it makes a difference. I think I was .0030-.0032 mains and .0024-.0026 rods on my clearances.
Only looking for about 600-650 Hp. What Grade should I go with?
1,611
Plus, a C gasket takes into account most any variable when it comes to protrusion. Protrusion beyond a C, Id think you'd want to start checking other parts, like the rod, piston or crank first.
Reactions: 1FastBrick
815
Moved this into its own thread. It wouldve gotten buried in the thread on my Regal.
Dont most people just go with grade C nowadays?
No worries. I originally thought that was the Monthly BS thread with all the thread derailment.
After I realized it wasn't, I knew you would fix it... :ROFLMAO:
815
So to answer all the questions, Yes I got the standard C as that is usually in most kits. Not a problem as I had no Idea what was needed until everything was machined and mocked up.
I want the engine to be as efficent as possible. On the Gas side of things, The Quench does make a noticable difference. Not sure if its the same in a diesel.
I had seen some questionable things posted in various places so I thought it better to ask. I would rather do it 1 time than be disappointed making a mistake or worse off having to do it over in the truck if it caused an issue of sorts...
Dallas S
485
33
Alberta
We have never had an issue keeping it tight at those power levels. Cold starts seem better and mpg definitely doesn’t suffer from tighter quench. I would be putting A on if I was ordering gaskets/availability
815
How much are they, in stock? I'd just assume to order them through Summit, the Mahle gasket is around $85
Of all places, Rock Auto shows them in stock. Couldn't find them anywhere else.
left is 58.79
right is 92.79
Not sure why the difference left to right but whatever.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,330
365
Central OH
A lot of stuff through Summit seems to be mfg direct order with a lead time. I've never experienced unnecessary wait though
