Head gasket or engine
Rafter J
Jul 28, 2023
Kerens, TX
While driving my 2002 duramax it instantly started blowing white smoke from the exhaust, it sucked all the coolant in the engine and appears hydrolocked. the shop I took it to said they pulled the glow plugs and got the engine to turn over but recommended I replace the engine. Is this the case or could it just be a head gasket issue?
1,756
Possibly one or more injector cups. Unless you bent a rod, I would not consider replacing the engine. There is a chance that erosion around the cups could be bad enough to warrant replacing the heads. But I'd inspect that before condemning the whole engine
