Anyone know where I can get the "h" gage or something comparable to check c5 clutch clearance?
The c5's I don't believe you can check with the tail housing bolted on. They are the clutches in the very back of the trans. If somehow you can I'm all ears but I don't see how unless you have a window in your trans.
You can get to them with the valve body on as well. I'm still curious to how they work! It's bass ackward from the way all the others are set up.
Yes you can I was having one of those dirt da der moments.
