Gt4294 which a/r????
dmaxbowtie
Duramax fiend
Jun 2, 2011
228
RI
Will be going with a looser converter for sure. Deciding the stall will be a whole different story. Going with the tightest a/r will allow me to switch to a larger a/r twice if need be to keep egts in check ?? And to reach my power goal
juddski88
Freedom Diesel
Jul 1, 2008
4,655
119
Chesterfield, Mass.
avoiding having to switch it up is why you are here asking questions right? I would take AJ's advice if it were my choice and run the 1.28 housing ungated and be done with it. I'd also run a Suncoast 1055 converter with it.:thumb:
dmaxbowtie
Duramax fiend
Jun 2, 2011
228
RI
Well I received the turbo the other day and they sent the wrong a/r. they sent a 1.28 a/r and I think I'm going to just give it a shot. They are willing to make right by it and send me the correct turbo or give me a good deal on a tighter ex. Housing if I try the 1.28 and don't like it.
Xternal
Aug 31, 2012
306
Jk. I think we're both along the same lines. I think I want to try the Garrett before the s472.
jkholder09
Jan 8, 2012
1,188
Maryland
I have one sitting on my desk, brand new I was using for mockup. It is calling my name.
I have heard all the hype on these turbo's.
Here is my hold back.
I have blown up a gtx4508r on this truck, and an efr9180.
That is 5000 dollars worth of turbo's.
I have a tendency to overspeed them.
The s472 I have on there now has went 11.3 @ 124 mph in a 7300 lb truck. It takes a lickin and keeps on tickin if you know what I mean.
Xternal
Aug 31, 2012
306
Can't beat that then. That makes me happy knowing it will take a beating. I would of assumed the borg to fail before a Garrett but apparently not. How'd you like the 4508
jkholder09
Jan 8, 2012
1,188
Maryland
Ok well I think we are just going to hijack this thread until the op can tell us how this turbo toes!!
Ok the gtx4508r ran like a scalded dog. It spooled up just like my s472/87 (both had the same size turbine and housing so why wouldn't they) In fact it may have even spooled better.
And as far as top end I have 5 tunes. tune 5 was almost clean on the 4508
tune 3 is clean now with the 472
I know I should change that but I mean, I guess I am hoping for something to clean it up.
Tune 5 was still too much for the 4508r it bent the shaft and started rubbing the cover in about 10-15 minutes. Now that 15 minutes was basically 1 wot run after the other hahahha
I run the 472 on tune 4 and tune 5 and it takes it.
Like I said I am sure the 4508 was about a 175 hp increase over the 472.
Xternal
Aug 31, 2012
306
Good information none the less. Certainly hijacking the thread but maybe some answers can come of it haha
