FUEL RETURN LINES
gerardo007
Oct 9, 2020
Hello, i an LLY, the return lines at the back of the truck are disconnected, anyone has a fuel diagram that shows where the last end of the fuel return lines are connected?
I believe a prior owner of this truck removed the lines that go back to the fuel cooler.
gerardo007
Oct 9, 2020
sorry i saw the lines, i have a massive fuel leak on injector 7, fitting retainer spring out and it drips a lot
Dozerboy
4,815
395
TX of course
Those plastic T’s in the injectors crack pretty easy. It probably needs to be replaced. I would buy a whole set. You might be able to swap that one out, but you might break more in the process.
Dozerboy
4,815
395
TX of course
