LB7: Fuel pressure tester?
sweetdiesel
That's better
Aug 6, 2006
10,390
51
Thailand
How do i check the fuel pressure and with what tool, can i do it with a standard fuel tester? What should the psi be. Thanks!
2004 Lb7
Re you reffering to the high pressure side or low pressure?
High press use EFI DVTs and ramp rail pressure up to 160 mPa.
And log rail pressure with scan tool.
Low press you would need a lift pump and then check at the port on the front by the alternator or T off the fuel hose somewhere as close to the cp3 as possible
Kennedy Diesel
Mar 13, 2009
66
What do i need to test it by the alt?
2004 Lb7
How about this:
