LB7: Fuel pressure regulator performance code
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
2001 lb7. New top end; head gaskets injectors lines etc. had some problems early but have the truck running and put some miles on it. Everything looks great balance rates within one, no other codes.
Rail pressure is at 10k. Commanded is 5k. Has a definite bump to the idle.
Am I looking at a new fuel pressure regulator here? Hung up?
This dang truck is determined to beat me.
paint94979
Beer Nazi
Sep 18, 2006
11,714
Sounds like a stuck regulator. What happens during highway driving, does actual follow desired?
sweetdiesel
That's better
Aug 6, 2006
10,390
51
Thailand
You're wrong James :D
No he isn't. I can watch rail pressure change on lots of vehicles just by turning on the lift pump.
Nick, it's a regulator and it's job is to adjust the pressure, if it sticks or has a lot of pre_ charge due to a lift pump it has to react....
Honestly Wade,I would not worry to much about it!
Logging at mid and wot would be a good idea though. If the truck hasn't been running for a while....drive it and see if the regulator loosens up.
