Fuel leak from injector return line fittings
Janimal444
354
Salem, NH
I had my injectors out, now several of the fuel return lines on top of the injectors leak. These were not damaged, are fully seated, and the hold down clips are on. It does not seem like rocket science to get these installed properly, what could I be missing?
ryan415
Oct 24, 2012
371
860
When I did my injectors one of the o-rings had a very small scuff in it. It was just enough to cause a leak. I replaced both fuel return hoses. There not expensive
dmax711
Mar 4, 2011
1,057
concord, north carolina
X2 they damage real easy and I replaced all mine last time it was apart as well.. alligator performance sells a kit that replaces either side.
07metallicgreen
Nov 24, 2011
207
Smicksburg, PA
i had the same thing. but im an idiot and broke 4 of them. two i knew i broke but the other two broke right above the o ring and i did not notice them when i put them in
Janimal444
354
Salem, NH
You guys were correct, a few of the plastic pieces had broken ever so slightly. Had to pull injectors today to clean the pieces out of there, I will buy those new lines tonight
