So for some reason my truck is dropping the fuel filter life real quick and will sometimes give me a p0087 but not all the time. I have done some reading on this and some say it could be collapsed fuel lines so I got to looking and found the one by the driver side valve cover was slightly collapsed so I squeezed it back round with a set of pliers and I still had the problem (I just got the hose to replace it but I need to get some new cutting disc for the drimel). When I first got the truck I put a ac delco filter on it (5000 miles ago) and I just tried replacing that today to see if that would fix it by chance and it didn't. I also noticed today that after I went out and drove the truck I would shut it off and was able to pump the fuel filter head like 5 times or so.
When I monitor rail pressure with my v2 the desired keeps up real well till it gets up around 20k and then it really doesn't want to keep up north of that. Some people have said it just needs a lift pump and I have also read that some people would put a lift pump on and it wouldn't fix the problem.
Also I noticed that that fuel line by the valve cover didn't really collapse again when I drove it last.
Anyway I'm just wanting advice on what you guys think and what I should do. Sorry if I was unclear with the problem. If you have any questions just ask and I will try to clarify.
