I need to figure out what to run for a fuel tank on my C10. I do not want to use the factory tank/s so i am wanting to run a fuel cell. The truck is an 1982 model and will need to pass inspection. Thanks guys
It's cause thy vent to atmosphere, john. All the fuel cells I've seen have breather tubes (they have to to keep a vacuum from forming in the tank)
Looks like anything made after 1980 is not allowed to vent gasoline vapors into the atmosphere. Why do they have to make things complicated? So where do i vent it?
Actually, you can't run a sump on the road either. But plenty of people do it.
yes but he has to go through an inspection so if the inspector feels what he put on it is not legal, hes screwed.
after its inspected, things can be "massaged" then . beadlocks are illegal too but people still run them on the street without issue
You really think they will bother you? All the DOT officers I've ever seen seem to be more interested in 18 wheelers.Passing an inspection is not a problem honestly, it's more of a DOT pullin me over while i'm east bound IH-10. I just need as much weight as possible over the rear axle
